Help with header install.
Old Nov 15, 2005 | 09:56 PM
tylerdru's Avatar
tylerdru
Default Help with header install.
ok, I cant figure out how to get these things in! Do you guys have any tips? I dont think i am getting the car up high enough to slip the headers in underneath. what did you guys do to get your headers in?
Old Nov 15, 2005 | 10:24 PM
dodgestang's Avatar
dodgestang
Default RE: Help with header install.
A bit more info would help like car, motor, header...but to take a stab....
Some headers require the motor to be lifted off the motor mount to install
Some headers can slide in from the top if you are good with puzzles
Some headers you have to drop the drag link out of the way to get the bolted up
Some headers have hard interference with drag link and can't installed
Some headers have hard interference with clutch setups
Some headers.....well...you get the point.
Do you have the car up on jack stands at the highest point?
Old Nov 15, 2005 | 10:31 PM
tylerdru's Avatar
tylerdru
Im sorry, i kinda of assumed that everybody knew. I have a 65 289 w/ manual steering and c4. I cant get the jack stands on the highest point due to the fact that the jack wont go high enough. I think i need to get a better jack that will raise the car up higher.
I The headers are flowtech long tubes.
Old Nov 15, 2005 | 10:38 PM
73Cleveland's Avatar
73Cleveland
ORIGINAL: tylerdru
To get the car higher, after the car is on the stands as high as the jack will go, lower the jack and put a couple of blocks of wood on the jack & jack it up further. This will give you a few extra inches of lift. and you can raise the stands further. Just maks SURE the blocks are secure and in a location where they wont "kick out".
Old Nov 15, 2005 | 10:47 PM
tylerdru's Avatar
tylerdru
okay, i will do that. i think that will get it high enough.
Old Nov 15, 2005 | 11:17 PM
73Cleveland
Let us know how the new headers sound!
Old Nov 15, 2005 | 11:23 PM
tylerdru's Avatar
tylerdru
I will! pretty soon i am going to be able to order all the little parts to get her running again!
Old Nov 15, 2005 | 11:45 PM
6mustang6's Avatar
6mustang6
BFH?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
junior04
Sep 28, 2015 10:53 AM
BrantleyS550
Sep 14, 2015 04:18 PM
