engine bay braces
Old Nov 26, 2005 | 10:01 PM
mayh3m's Avatar
mayh3m
Default engine bay braces
i've seen numerous engine bays with a number of different support braces in them. does anyone have a factory 289/302 engine bay shot so i can see the support braces i need?
edit: will the 2 strut tower braces for the i6 be sufficient?
Old Nov 26, 2005 | 10:25 PM
lClutchl's Avatar
lClutchl
Default RE: engine bay braces
what year?
Old Nov 26, 2005 | 11:04 PM
mayh3m's Avatar
mayh3m
my bad, 67 i6
Old Nov 26, 2005 | 11:18 PM
lClutchl's Avatar
lClutchl
Well it's not original... but the bracing isn't to different.
The one in the front is not standard. The one that goes from shocktower to shocktower in the back is actually two pieces in the stock form. The stock bracing should work great for you with a I6.
Old Nov 26, 2005 | 11:54 PM
valley firearms's Avatar
valley firearms
Damn Clutch, that looks sweet!
Old Nov 27, 2005 | 12:25 AM
lClutchl's Avatar
lClutchl
Thanks VF! Took me 5 weeks.
Old Nov 28, 2005 | 09:08 AM
Soaring's Avatar
Soaring
I ♥ Acer
I'll be adding the export brace and the Monte Carlo bar to mine shortly. The two piece shock tower to cowl will probably be just fine for the I6 though. The Monte Carlo straight bar will work well instead of using the curved bar as Clutch has. He has the oval air cleaner, so has to use that one to clear the cleaner.
Old Nov 28, 2005 | 06:08 PM
mayh3m's Avatar
mayh3m
i'm dropping in a 289 tho
Old Nov 28, 2005 | 08:00 PM
6mustang6's Avatar
6mustang6
I thought the export brace and the fender tower to cowl is the same thing Glen?
Old Nov 29, 2005 | 08:14 AM
Soaring's Avatar
Soaring
I ♥ Acer
No, the export brace is one piece, whereas the shock tower to cowl is actually 4 pieces. Remember when I was corrected by Nick?
