Holley or Edelbrock Carb?
Old Dec 13, 2005 | 03:31 AM
351foxstang's Avatar
351foxstang
Default RE: Holley or Edelbrock Carb?
hi guys,
any one have any experience with barry grant demon carbs? i was planning on one for my 393w build. it will be a fairly modified motor.
thanks,
carl
Old Dec 13, 2005 | 03:50 AM
Dan66Stang's Avatar
Dan66Stang
ORIGINAL: gconnsr
Yep!
So, by looking at my sig, should I go for the 570 or 670?
Old Dec 13, 2005 | 08:37 AM
65_2plus2's Avatar
65_2plus2
After spending months trying to tweak and fine tune the Holley 650 carb, I gave up. At the same time, I was messing around with an Edelbrock on my wife’s car (350 Chevy) and it was a piece of crap too. I opted for a Holley 670 Throttle body on the 289 and what a simple 10 min joy to set it up. I opted for a Berry Grant 650 on the Chevy 350 and what a joy that was. [sm=smiley20.gif]
My choices would be a Fuel injection as a first choice and a BG Speed Demon as a second choice.
Cheers.....[sm=icon_cheers.gif]
Old Dec 13, 2005 | 09:36 AM
lClutchl's Avatar
lClutchl
Edelbrock is by far easier to tune. Tuning doesn't require you to pull any part that is below the fuel level of the carb, so no mess. Instead of jets you put rods and springs in to meter the fuel. Access to them is via to openings in the TOP of the carb.
I switched over from a Holley 4160 that was a major PITA to tune. Every time you needed to change the jets, you had to pull the carb, empty the fuel bowl, and take 60% of the thing apart to get at them. Not to mention that the carb was only 6 months old and already leaking heavily thru the throttlebody rods.
The Edelbrock has a nice little 5 page set of tuning instructions... The Holley has a document that heavly refers to other documents, some of which recommend taking a drill and poping holes in the butterflys to get a proper tune out of them.
For performance go Holley, but for reliability and daily driving the Edelbrock wins hands down.
Old Dec 13, 2005 | 10:05 AM
earlymustang's Avatar
earlymustang
I have an Edelbrock Performer Series 600 cfm - Electric Choke. I had heard great things about the Autolite 4100 but the one I received from Pony Carb's just didn't have the throttle response and wouldn't idle for crap.
Although I don't like the look of the Edelbrock, it ran almost perfect out of the box and was only 240.00 vs. the 500.00 I spent w/Pony Carb.
I really don't think you can go wrong w/either Edelbrock or Holley.
Old Dec 13, 2005 | 10:23 AM
Soaring's Avatar
Soaring
I ♥ Acer
If you want the most reliable carb out there, then get a Motorcraft 4100. There is a good reason why Ford put those on at the factory.
Old Dec 13, 2005 | 11:00 AM
jrrhd73must's Avatar
jrrhd73must
I like the edelbrock. Very easy to tune - I have tuned one. My has run very well for 10 years now.
My drag race freinds used to run the edelbrock now they are all switching to Demons.
Old Dec 13, 2005 | 11:50 AM
Silver Ponys's Avatar
Silver Ponys
I have heard that Carter AFB's are the same as an Eldebrock and a little cheaper. I use a Holley 600
Old Dec 13, 2005 | 02:01 PM
gconnsr's Avatar
gconnsr
A Demon is a Holley copy, I'm glad your freinds finally woke up! They must have been slow, because an Edelbrock can't hold enough fuel, even with mods, to feed a 10sec motor, not to mention a hop up kit is very expensive, unlike Holley. There is a reason B.G. and Demon are modified Holleys. If you read the directions on your new Holley, it is very easy to tune and very easy to mod.
Old Dec 13, 2005 | 03:02 PM
Dan66Stang's Avatar
Dan66Stang
It seems that overall, everyone seems to be 50-50 between the two. I guess Im gonna go with the Holley Street Avenger 670 (http://www.holley.com/types.asp?type=7). That has an elec choke and Vac Secondary.
