Carb, Intake, what else????
Old Dec 26, 2005 | 02:18 AM
Dan66Stang's Avatar
Dan66Stang
Default Carb, Intake, what else????
Hey guys, I've decided to get an Edelbrock carb and intake. Now, my question is, is there anything else I have to buy? Do I need to replace anything else? Its just a swap, Im taking off the old ones and putting these on. I would like to get all the parts before I start. Thanks
Old Dec 26, 2005 | 10:13 AM
gta289's Avatar
gta289
Default RE: Carb, Intake, what else????
not a bad idea to replace the rocker arms and lifters while your in there. No sense in putting more power into your motor if the top end is old and ready to die.
Old Dec 26, 2005 | 10:22 AM
tylerdru's Avatar
tylerdru
You might need new temp sending units, the heater fitting, most likely plugs, Vacuum line fittings for transmission, more wire to hook up electric choke. Most of this stuff might be in good condition on the other manifold and you can just take them off. Everything on mine was rusted,
Old Dec 26, 2005 | 11:22 AM
gta289's Avatar
gta289
even so take a wire wheel to them,(the metal parts people!) and clean them up. Fot the vacumm fittings in the intake i use castrol super clean engine degreaser in a cool whip container(empty of course) and let them sit in there for a little while, than used the air compressor to dry it out, slapped a new o-ring in and was ready to go
Old Dec 27, 2005 | 11:05 PM
Silver Ponys's Avatar
Silver Ponys
Might want to pick up a new thermostat housing,the old ones are usually pretty coroded. Ford Motorsport has a housing with a o-ring seal that looks good. Stick a new thermostat in while you are there
Old Dec 28, 2005 | 12:37 AM
Markstang1969's Avatar
Markstang1969
Have you upgraded the ignition yet?
Old Dec 29, 2005 | 05:47 PM
Dan66Stang's Avatar
Dan66Stang
ORIGINAL: Markstang1969
No, should I??? If I don't, what will happen?
Old Dec 29, 2005 | 06:00 PM
mlitz's Avatar
mlitz
well nothing will happen it is just a good idea since u are already it that area of work....
Old Dec 29, 2005 | 06:10 PM
69boss429's Avatar
69boss429
Unless you are changing rhe camshaft do NOT replace the lifters !How many miles are on this engine now ??
Old Dec 29, 2005 | 07:33 PM
Dan66Stang's Avatar
Dan66Stang
ORIGINAL: 69boss429
Look in my sig, my engine was rebuilt about 4 years ago. Taking a shot at it, Id say it has about 20K on it...
