70mach 1 351w engine help
Old Dec 28, 2005 | 11:55 PM
70mach1's Avatar
70mach1
Default 70mach 1 351w engine help
i have a 70 mach 1 with 351w in it but i want to give it some more umph in horsepower. Does anyone have advice on easy things to install on a budget? thanks
Old Dec 29, 2005 | 01:29 AM
69mach1377's Avatar
69mach1377
Default RE: 70mach 1 351w engine help
Get a cam, spring, lifter and intake kit from edelbrock along with a 4 barrel carb and headers to get you started on the path to power. I'm assuming you now have a 2 barrel H code? Get some new heads for the most benefit.
Old Dec 29, 2005 | 02:31 AM
70mach1's Avatar
70mach1
no i have a 4 barrel m code and i already have a weiland intake on it. by replacing the cam will it require a lot of tuning ? how much would this cost and how much do u think it would improve?
Old Dec 29, 2005 | 02:34 AM
70mach1's Avatar
70mach1
the carb is also a new edelbrock and works well.
Old Dec 29, 2005 | 11:42 PM
69mach1377's Avatar
69mach1377
summitracing.com or jegs.com will have cam and lifter kits. It's good to know how much valve to piston clearance and valve lift you currently have before choosing a new one. A higher lift and duration cam can make noticalbe power imrovement. Try desktop dyno software for kicks.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
