Bigger 302 valves?
Old Jan 12, 2006 | 03:55 AM
onuliakattack's Avatar
onuliakattack
Default Bigger 302 valves?
Ive decided to rebuild my 302, and have edelbrock performer package(minus the heads) on it and was just wondering if buying bigger valves for my stock heads is the way to go, the stock size i have on now is 1.78" intake and 1.45" exaust. Anyone know what size valves I should get if i want to go bigger, or is it even going to make a noticeable difference. Oh and how much would the valve job cost to make the seats bigger? Anyone whos used this setup? Thanks guys.
Old Jan 12, 2006 | 12:44 PM
Jaye's Avatar
Jaye
Default RE: Bigger 302 valves?
yeah dude my borther done that got the bigr valves n heads worked real good 2!! u need like i think its 2 inche valves n don't forget 1 valve is bigr than the other!!
Old Jan 12, 2006 | 12:48 PM
Sidewayz6.0's Avatar
Sidewayz6.0
I find it completely unbelievable that you continue to post even though nobody can see what you're saying.
Old Jan 12, 2006 | 02:09 PM
351foxstang's Avatar
351foxstang
im not sure about how large you can go on the heads you have. but to get mine cut for 2.02/1.60" valves and a 3 angle valve job it was going to cost about 700, not including parts. i am going to get a set of after market iron heads with 2.08/1.60" for slightly more money.
you should call a couple machine shops local to you and ask them about prices and what they can do for sizes.
Old Jan 18, 2006 | 03:34 AM
onuliakattack
thanks dudesters, ill call my shop teacher and ask him for a reputable machine shop.
Old Jan 18, 2006 | 11:01 PM
JBradley500's Avatar
JBradley500
From what I understand, that if your small block is built on the mild side and more for the street, that anything over 1.94" on the intake side is always going to make you lose power.
Old Jan 18, 2006 | 11:35 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I am completely against doing this kind of mod. When you turn yourself over to the mercy of the machinest it can tend to be trouble. For that kind of money you almost have enought to get a set of Trick Flow aluminum heads. They are lighter. they have the big valves. They are ported and ready to slap on. I have done 2 sets and have had great luck with them. Got them for about $800 a set.
Old Jan 19, 2006 | 03:18 AM
Magiarn71's Avatar
Magiarn71
Yeah, even if you had to spend like $300 more......to pay $700 for bigger valves in an old, stock head is nuts.
Old Jan 20, 2006 | 09:53 PM
onuliakattack
Yah Ive decided to get rid of my stock heads and go for some aluminum ones like edelbrocks performers to go along with my engine rebuild once i sell my jeep. Just seems more logical to go aluminum. Anyone know of a little cheaper brand of aluminum heads other than edelbrocks(1100-1200$$) im only 17, work part time and make minimum wage so i have a budget... thanks for the info guys.
Old Jan 20, 2006 | 10:41 PM
dcohen's Avatar
dcohen
You might could go on ebay and look for some heads. But be VERY cautious before you buy anything. But remember sometimes you find a diamond in the rough
