Export brace
Old Jan 23, 2004 | 11:00 PM
rshep's Avatar
rshep
Default Export brace
I've got a `65 fastback. The export brace that I have doen't quite fit. Is there a trick?
Old Jan 25, 2004 | 11:58 AM
quig's Avatar
quig
Did the original braces fit right? Aftermarket parts dont always fit match the holes from the originals to the export. If they match your body is sagging with bracing removed jack car up a little under rear of front frame rail then install that side then repeat for other side.</P>
Quig</P>
Old Feb 6, 2004 | 11:59 PM
bob emmerich's Avatar
bob emmerich
Jack the car up off the ground using the front crossmember(the bar directly under the engine) and let it sit that way for a while. This will let the shock towers "relax" and it should fit in place.
guitarman376
Oct 11, 2015 01:47 AM
Sep 17, 2015 07:57 PM
Sep 16, 2015 07:53 PM
Sep 1, 2015 08:16 PM
