fuel guage
Old Jan 18, 2006 | 04:27 PM
daver's Avatar
daver
Default fuel guage
ive got 68 coupe and the fuel guage doesnt work. Why dont the old stangs have a ground strap from the tank to the frame? i thought this was the problem but i foudna pic and it didnt show a ground strap. The wire runs straight from the sending unit to the guage. Any one know what all is involved with these guages??
Old Jan 18, 2006 | 05:15 PM
dcohen's Avatar
dcohen
Default RE: fuel guage
Your sending unit is probably bad. They cost about 30 bucks so make sure before you buy something you dont need.
Old Jan 18, 2006 | 05:37 PM
67t5ponycoupe's Avatar
67t5ponycoupe
with the key on, pull the wire off of the sending unit. ground it to the frame. If the gauge pegs out (full) then you have a bad sending unit. If it does not peg it is either a bad gauge or bad wiring to the gauge.
Old Jan 18, 2006 | 05:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
If it doesn't peg the gauge, then the gauge is probably bad., or the wiring to the gauge is broken or disconnected. And, I caution you to not ground it to the gas tank. BOOM! Here is a pic of the sending unit on my 65. It should look the same as your 68.
Old Jan 18, 2006 | 06:06 PM
BillyBobJoe's Avatar
BillyBobJoe
its usually the sender but it doesnt hurt to make sure
Old Jan 18, 2006 | 07:20 PM
dcohen's Avatar
dcohen
Who needs a fuel gauge anyway?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
