radio wires
Old Jan 22, 2006 | 02:48 PM
mlitz's Avatar
mlitz
Default radio wires
i just got me new am/fm/cd option radio that will fit in to my stock location. there are two wires to hook up to the battery one is on when the key is on and the other is on all the time and the manual said to go through a fuse. any ideas or what u guys did, to hook them up......?
Old Jan 22, 2006 | 06:40 PM
mlitz's Avatar
mlitz
Default RE: radio wires
bump!
Old Jan 22, 2006 | 11:56 PM
slickman's Avatar
slickman
One is hooked to a switched hot lead and the other is on a hot lead all the time. The one that is on a hot lead all the time is for memory so it retains you channel selections.
Old Jan 23, 2006 | 01:39 AM
mlitz's Avatar
mlitz
I'm not stupid i know that.......[:@] were do i hook each of them up they say they need to go through fuses, were do i connect them.....
Old Jan 23, 2006 | 08:37 AM
slickman's Avatar
slickman
You can hook the one that needs switched power to the power lead off the radio, That one has power only when the key is in the run position. The other one you would need to hook up to the dome light (or some other wire that has power all the time), I think that one has power all the time. As to fues's, I would put a fuse in line with each one and the size sepends on the radio. That could be anyplace from 1 to 3 amps I think.
By the way, no one was stating you were stupid. When someone aks's a question like that, its assumed they have no clue about wiring stereo equipment.
Old Jan 23, 2006 | 12:07 PM
jrrhd73must's Avatar
jrrhd73must
I used a multimeter to find out which fuse was live. Then I soldered the radio wire into the fuze box.
Old Jan 23, 2006 | 04:58 PM
rollin66's Avatar
rollin66
ORIGINAL: jrrhd73must
what he said.... it's the easiest thing to do and you have easy access to it. Just be careful soldering...
Old Jan 23, 2006 | 06:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
You say you found an AM/FM radio with a CD player that fits into your stock location? I didn't know they existed. Tell me what it is.
Old Jan 23, 2006 | 08:42 PM
6mustang6's Avatar
6mustang6
Theres no way he did, unless it's a 67 or up.
Old Jan 23, 2006 | 11:27 PM
slickman's Avatar
slickman
What he said...
ORIGINAL: 6mustang6
