Wrong tire size = an off speed?
Old Jan 30, 2006 | 07:38 PM
Elvish Legion's Avatar
Elvish Legion
Default Wrong tire size = an off speed?
Will tires that are over sized cause a cars speed to read high?
Old Jan 30, 2006 | 08:02 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Wrong tire size = an off speed?
No it will read too low
Old Jan 30, 2006 | 08:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
See if this chart helps. http://www.4lo.com/4LoCalc.htm
Old Feb 1, 2006 | 09:44 PM
Jsprint68's Avatar
Jsprint68
Try this!
Randy's Ring & Pinion
Old Feb 2, 2006 | 01:04 PM
65GTin GA's Avatar
65GTin GA
Anytime you change the tire size (diameter) you will change the speedometer reading. Say you install 23.5" diameter tires. Multiply 23.5 times 3.14 to get the circumference in inches (73.79) divide by 12 to get it to feet (6.149) and divide this into 5280 (feet in a mile) and you have the rpms of the wheel at 60 mph (858). To figure out the gears you need on your speedo cable to get the speedometer reading correctly use this formula:
Driven gear teeth (on cable) equals Drive gear teeth on tranny output shaft x rear end ratio x revolutions per mile
1000
For example : A tranny with a 6 tooth gear x 3.25 rear end x 858 equals 16,731
Divided by 1000 equals 16.73 You round this to the nearest whole number and you would need a 17 tooth gear on the cable to have a speedometer reading accurately.
Old Feb 2, 2006 | 07:07 PM
67t5ponycoupe
Man that is some great information! I always used the tried and true method of yanking the gear out and the trying one with more or less teeth until I got it as close as I could.
Old Feb 3, 2006 | 12:38 PM
65GTin GA's Avatar
65GTin GA
Glad all that formula stuff was helpful to someone. Could have saved me some problems if I knew it when I replaced the speedo gear on my tranny output shaft. Apprently I put an eight tooth on my Toplaoder and now with my 225x50's and a 3.25 rear, I need aabout a 22 tooth speedometer cable gear (they go to 21!) With a six tooth gear it would be a 17. Darn. Oh well, I will live with the offspeed until I get a T-5 and then get it right.
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
