Power Brake push rod
What's the best way to adjust the "power brake" push rod? I think it needs to be adjusted, I just installed a new boster and master in my "Disk Brake Conversion". I did bench bleed the master and also did the system bleed using a power bleeder. So, there is no air in the system at all...
The has a firm feel but, has too much travel. With it mounted in the system, can I just move the brake pedal (engine off) till I see the rear brakes move and then back it off a bit. Then use that position as the rest position for it and adjust it there?
mungodrums
Oct 7, 2015 04:01 AM
66, 68, adjust, adjustable, adjustablebrake, adjustment, brake, brakes, mustang, power, powerbrakes, push, pushrod, rod, rods
