289 vs. 302 block
Old Feb 2, 2006 | 11:01 PM
redstallion's Avatar
redstallion
Default 289 vs. 302 block
I've heard that the cylinder walls extend further on the 302...
if this is true, can a 347 stroker kit still be used on a 289 block or is the cylinder not quite long enough?
I haven't heard of anyone using a 289 block for these strokers....does anyone know for sure if it will work?
Old Feb 2, 2006 | 11:06 PM
Twister's Avatar
Twister
Default RE: 289 vs. 302 block
the cylinder sleaves are shorter in 289
Old Feb 3, 2006 | 12:19 AM
6mustang6's Avatar
6mustang6
It can be done, the block has to be notched, thats all.
Old Feb 3, 2006 | 01:10 AM
KBunny's Avatar
KBunny
but strokeing it to a 347 would put alot more strain on the little engine wouldnt it? wouldnt you just want to get a 351 and not have to worry about breaking something? by useing a those small blocks to get 347ci out of it are you really saveing that much weight by doing it?
Old Feb 3, 2006 | 12:04 PM
slickman's Avatar
slickman
I beleve the 302 and 351 use the same block.
ORIGINAL: KBunny
Old Feb 3, 2006 | 12:09 PM
Twister's Avatar
Twister
no, a 351 is taller, wider, and has a different oil pan. To most untrained eyes, they look the same
Old Feb 3, 2006 | 12:22 PM
redstallion
i know that either block will have to be notched
My only concern was whether or not the sleeves are long enough on the 289, but it sounds like they are
i already have a 289 so building a 351 would be significantly more money.....(I'm trying to become a licensed skydiver, and build an engine, and i'm full-time in college.....i'm gonna run out of money [:@])
Old Feb 3, 2006 | 02:24 PM
351foxstang's Avatar
351foxstang
a 331 stroker might be safer to use on the 289 block. ive also heard of the 347's not being as reliable.
i just ordered a cast 331 crankshaft last night for my brother's car. its made by eagle and was 10/10 undersize. it only cost $107. im going to check it out once it comes in, ill let you know how it looks. link
carl
Old Feb 3, 2006 | 10:54 PM
redstallion
carl
Cool, let me know how it goes.....and is your brother's a 289 or 302?
Old Feb 3, 2006 | 11:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
The 289 and 302 blocks are the same.
