1968 Tail Light Panel Replacement
Old Feb 6, 2006 | 04:38 AM
Shifty101Easy's Avatar
Shifty101Easy
Default 1968 Tail Light Panel Replacement
ok, the car im buying this weekend has a small hole in the tail light panel. i figured its pretty cheap to get a replacement panel so i thought i would just do that...but then i couldnt figure out if it needs to be welded in or bolted in....can anyone help me????
if it needs to be welded in, how much would it probably cost a shop to do it for?
I could always patch up the hole also....but it seems easier...and just cleaner to replace the whole piece....
Old Feb 6, 2006 | 04:48 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: 1968 Tail Light Panel Replacement
It is welded in. Not that hard to do, not that easy either. If it is one small hole and the rest of the panel is ok I would consider patching it.
Old Feb 6, 2006 | 04:50 AM
Shifty101Easy
yeah...its probably about the size of a quarter or less...with some surface rust surrounding.
i dont have any welding stuff personally so id have to take it somewhere....how much would that end up costing do you think...?
i guess theres always the body filler or fiberglass patching options too....
Old Feb 6, 2006 | 05:11 AM
351foxstang's Avatar
351foxstang
you would need to get some solid metal behind the hole before you could body filler it.
Old Feb 6, 2006 | 05:20 AM
Shifty101Easy
well i meant like put the fiberglass strip across the back...then put some filler in there on the front.....i dono though....if its small enough...i dont think i will mind...but if its bigger looking in person....ahh just might have to get it fixed for real...i wouldnt even know if im getting ripped though since i dono how much a little hole is to fill...on average.
Old Feb 6, 2006 | 02:10 PM
baddog671's Avatar
baddog671
If you have the money go ahead and buy the new panel and fix the problem for good. Whos to say that next year after you plug it, the plug wont fall out? I think they are under 100 bucks but im not sure...
Old Feb 6, 2006 | 03:26 PM
351foxstang
i just looked it up on cjponyparts. it was $60 plus shipping.
Old Feb 6, 2006 | 09:21 PM
Shifty101Easy
yeah i mean ive found it even cheaper elsewhere....(free shipping)....but thats not my point...my point is how am i going to weld this thing in there without any welding supplies and not too much welding experience? thats why im wondering if its gonna cost me my soul to get it welded in by someone in a shop....
Old Feb 6, 2006 | 09:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Shifty101Easy
That's easy enough to find out. Take the car to a body/welding shop and have it estimated. If you like the price, do it. If not, don't. You guys spend too much time on simple things.
Old Feb 6, 2006 | 09:37 PM
Shifty101Easy
yeah....thats my problem though...i dont know what a fair price for that is......i was just curious if someone could give me a ball park.....like..... $25-50 bucks or $50-75 or $11,500-29,000....
u know....just so i can go there with some sort of idea what the going rate for welding a panel in is.....im sure they will tell me whatever their rate is, is the going rate....
