302 or 351?
Old Feb 7, 2006 | 08:02 PM
dcohen's Avatar
dcohen
Default 302 or 351?
What are the obvious visual differences between a 302 and a 351w?
Old Feb 7, 2006 | 08:28 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: 302 or 351?
351w is taller and wider....more displacement....i dono about bores but id assume its bigger....
Old Feb 7, 2006 | 08:31 PM
bdwjdw's Avatar
bdwjdw
The top of the water pump flange is flush with the deck on the block on a 302 & on a 351 the deck is about 1 inch above the water pump flange.
68FastbackGT's Avatar
68FastbackGT
They do look very similar. The 351 is a bit taller and therefore the intake manifold is wider.
Old Feb 8, 2006 | 02:22 AM
GypsyR's Avatar
GypsyR
289/302.5.0's have an intake that is right about 9 inches wide, valve cover edge to valve cover edge. A 351W is about 11 inches wide. The two inches difference is easy to spot after you've looked at a couple examples of each.
Galactic
Apr 29, 2019 02:56 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
69Volunteer
Sep 30, 2015 10:39 AM
jaiidutch
Sep 14, 2015 10:29 AM
