65 engine swap
Old Feb 12, 2006 | 04:35 PM
aj05must's Avatar
aj05must
Default 65 engine swap
im looking to put a crate engine in my 65 mustang. the engine i want has a rear sump fox style 5 qt oil pan and sending unit. anyone have any idea as to how hard it would be to change this to fit into a 65??
Old Feb 13, 2006 | 03:02 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: 65 engine swap
just unbolt the oil pan and swap the pickup tube with correct one and bolt on the correct oil pan u will probably need another timing cover also and make sure u get the correct flywheel for the application
Old Feb 13, 2006 | 09:39 AM
THUMPIN455's Avatar
THUMPIN455
yup, thats about all there is to it. Later engines have a different flywheel/flexplate balance and will damage older engines. So if you are pulling it out, and the donor has the same type trans your car does (auto/manual) keep the flywheel/flexplate. If it is a 5 speed engine goin in an auto car, you wil have to buy a late flexplate.. get the idea?
Old Feb 13, 2006 | 11:27 PM
aj05must's Avatar
aj05must
yess. thank you very much
Old Feb 14, 2006 | 07:34 PM
hutchamatic's Avatar
hutchamatic
Yep you can pick up a new oil pan for around $45.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
