Kick panel difference?
Old Feb 13, 2006 | 02:33 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default Kick panel difference?
What is the differnece between a 66 and a 67 kick panel? Does anyone know if a 66 kick panel will fit in a 67? I need white for my 67 and it is not availible in white. They look the same on the mustang plus site.
Old Feb 13, 2006 | 01:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Kick panel difference?
ORIGINAL: 67t5ponycoupe
They are different. Get some white vinyl dye from a Mustang vendor, and just dye them.
Old Feb 13, 2006 | 03:37 PM
Shifty101Easy's Avatar
Shifty101Easy
yeah thats what they say to do in the catalogue.
Old Feb 13, 2006 | 07:27 PM
cordoba@California's Avatar
cordoba@California
yeah they tell you that then you have to buy something
Old Feb 13, 2006 | 07:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Well, duhhhhh! If you want to change the color of your kick panels, and you can't find the right colors by buying new ones, then the alternative is to dye yours the color you want them. That equals having to buy some vinyl dye.
Old Feb 13, 2006 | 08:55 PM
Twister's Avatar
Twister
65-66 have a "flat" accent, while the 67-68 is "peaked. the 67-68 is slightly taller. 67 parchment is an off-white. The only white available then was 65, and that was a cream
Old Feb 13, 2006 | 09:41 PM
67t5ponycoupe
Thanks for the inputs
Old Feb 13, 2006 | 09:50 PM
Soaring's Avatar
Soaring
I ♥ Acer
John, there is one other thing you may want to consider. Don't try to line up the holes in your original kick plate with the new kick plate. In other words, set your new kick plates where you want them, then drill new holes for the screws. There are four if I remember correctly.
Old Feb 13, 2006 | 09:55 PM
Shifty101Easy
are you getting the ones with the speaker holes?
Old Feb 14, 2006 | 02:33 AM
67t5ponycoupe
Not sure about that yet
