Help Mounting 2006 wheels on 1965 model
Old Feb 19, 2006 | 01:16 AM
ejnordstrom's Avatar
ejnordstrom
Default Help Mounting 2006 wheels on 1965 model
Would like to mount a set of the new 2005/06 Mustang wheels on my 1965 model. I've heard I'll need an adapter kit to do this. Something about the bolt pattern is different. Can anyone confirm ? Has anyone changed their wheels ? Where can I get an adapter kit ? Does it messup the look of the car?
Old Feb 19, 2006 | 01:45 AM
dcohen's Avatar
dcohen
Default RE: Help Mounting 2006 wheels on 1965 model
you probably will need some spacers to keep them from fitting right, im not sure about the bolt patter though
Old Feb 19, 2006 | 03:22 AM
67t5ponycoupe's Avatar
67t5ponycoupe
I've got 05's on my 67. I needed 1 1/4 inch spacers to make it work. I think 06 is the same. The bolt pattern is the same i'm sure. The problem you will have is the new ones use a 6 inch backspace and the old stangs us a 4 1/2. They recommend a 1 1/2 inch spacer but I got by with a 1 1/4. It is really freaking close to the upper A arm though.
[IMG]local://upfiles/27838/A979EA1C4C68465697F9A15EE409A520.jpg[/IMG]
Old Feb 19, 2006 | 06:12 AM
Shifty101Easy's Avatar
Shifty101Easy
spacers are expensive too huh?
Old Feb 19, 2006 | 06:32 AM
67t5ponycoupe
I think they were about $120 for a set of 4
Old Feb 19, 2006 | 12:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 67t5ponycoupe
Which extended bolt package did you get with the spacers?
Old Feb 19, 2006 | 12:19 PM
tylerdru's Avatar
tylerdru
I got a dumb question. The rims i was looking at had a backspacing of 3.75 Would these fit without modification.
Old Feb 19, 2006 | 02:44 PM
67t5ponycoupe
As far as back spacing they should fit. It would depend how far they stick out.
Old Feb 19, 2006 | 06:48 PM
Shifty101Easy
6 inch wont fit even with spacers right?
Old Feb 19, 2006 | 08:30 PM
67t5ponycoupe
6" inch back space with 1 1/4 spacers is what I'm running.
Soaring, extended bolt package? The stock studs would not allow the lugs to grab the entire stud with the spacer on. It was really close and might have worked but in the interest of safety I changed to a longer stud. Don't want them thar wheels a comin' off!
