Engine Swap
Old Feb 19, 2006 | 05:24 PM
bdwjdw's Avatar
bdwjdw
Default Engine Swap
I'm sure this question has been asked before but I couldn't find it. I am wanting to put a 302 out of my 95 stang in my 65 stang, what will I need? I know of a few things like the oil pan, distibutor gear, and flywheel. I know that my 95 has a 50oz flywheel but not sure about the 289 that came out of my 65, is it 28oz or 50oz? Is there anything I'm missing?
Old Feb 19, 2006 | 11:17 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: Engine Swap
The early engines had 28oz but if you already have the flywheel it will work. They arent hard to find in any case. Oil pan, pickup tube, and the distributor gear only needs changed if you switch from a factory cam. If I remember correctly, the stock engines had a cast iron gear on the cam so they didnt have to use a bronze gear like you do when you run a billet cam in a solid roller setup.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
