pertronix
Old Feb 22, 2006 | 10:34 PM
speedjunkie's Avatar
speedjunkie
Default pertronix
does anyone know the air gap between the module and magnet sleeve for the petronix.
Old Feb 22, 2006 | 10:40 PM
slickman's Avatar
slickman
Default RE: pertronix
The air gap between the Ignitor module and the magnet ring must fall between .010-.060-inch.
Old Feb 22, 2006 | 10:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
The pertronix module comes with a clear plastic gauge. Use that to determine the space. If you don't have one, get back.
Old Feb 22, 2006 | 11:04 PM
speedjunkie
i changed my distributor and forgot to check the gap before i transfered it to the new one. it was allready installed in the old one when it was given to me so i don't have the instructions or the plastic gauge. i set it at .030 but i wanted to make sure it was right.
Old Feb 22, 2006 | 11:10 PM
slickman's Avatar
slickman
Well then you got it my friend, right dead center....
ORIGINAL: speedjunkie
Old Feb 22, 2006 | 11:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
That's right. I just went out in the garage and read my instruction sheet, and it says to set it at 0.030 which is the thickness of the plastic gauge.
Old Feb 22, 2006 | 11:15 PM
speedjunkie
thanks guys
Old Feb 22, 2006 | 11:19 PM
slickman's Avatar
slickman
4reboy
Feb 19, 2007 04:28 PM
bw71mach1
Jan 25, 2007 08:32 PM
plainsmen
Jun 30, 2006 11:48 PM
nualln
Jun 1, 2005 06:33 PM
Soaring
May 6, 2005 03:27 PM
