Getting top to go down further?
Hey guys,
I always thought that my top didn't look like it went down as far as it should.
I managed to pick up a top boot, and it doesn't fit.
This just reaffirmed my theory that the top didn't go down as far as it is supposed to.
So here's my question,
Have any of you encountered a similar problem?
Does anybody know how to make it go down further?
Adjustment points etc.?
Thanks!
Thanks!
Not to be rude
There's nothing in the trunk. I even took the trunk interior piece out to be sure that wasn't the issue.
Also are you closing the latches after you unhook them??
I've taken the interior 1/4s out, and found at least one point that makes the top go down a little more. (Already did)
Somebody has to have had this problem before!
Sorry, I was talking about the area just infront of the rear window, but behind the back seat. I haven't had this problem before, but if you can find where the top is touching something else then you can find your problem.
IF YOU FIGURE THIS OUT LET ME KNOW. MY 86 DOESN'T WORK SO I HAVE TO PUT IT DOWN MANUALLY. IT DOESN'T GO DOWN FAR ENOUGH BUT I FIGURE THATS BECAUSE THE TOP IS OLD AND STIFF. I'M NOT GOING TO WORRY UNTIL I PUT ON A NEW TOP. I'LL MAKE SURE IT WORKS THEN. YOUR NOT ALONE. GOOD LUCK.
My 95 GT last weekend developed a similar problem. Mine goes down all the way, but it will not go closed completely. It stops 2”-3” equally across from the windshield, (3 weeks ago it was closing all the way on the right side and stopping short on the left side) so I removed the rear interior quarters I didn’t find any magical adjustment that cured the problem. I did loosen the adjustments (for what is was worth) and let the car sit out in the hot sun and this improved things aprox. 90%.
I noticed that the top is so tight the arch is a little flat; you can really see it when you put the windows up and it pushes the top into shape.
Good thing I had an appointment to get a new top before this BS began.
Can you push the top all the way down after your motor stops? ifnot then something has to be catching the frame somewhere.And when you close it, its not supposed to come all the way to the windshield frame. that extra 2-3 inches is so that the top stretches and doesnt flap in the wind, and it pulls the wrinkles out of it.
