MY 1/4 WINDOWS
Old Apr 20, 2007 | 05:02 PM
Demolisher's Avatar
Demolisher
Default MY 1/4 WINDOWS
Ok well i wanna put my top down but it sux that my1/4 winodws dont work right idk what it is i mean they go down when the button but i kinda have to push them down a bit , but them to pick them back up i have to grab pliar's and help them back up while i push the button and it really sux trying to lean over and pick them up wit the pliars in one hand and trying to click the button wit the other hand plz help guys [>:]
Old Apr 21, 2007 | 01:42 AM
92stang5.0's Avatar
92stang5.0
Default RE: MY 1/4 WINDOWS
I had one window with that problem. There is a plastic gear inside the motor that is probably shot, I've had that problem with both my mustang and a Bronco II I had, hope this helps, its a pain in the *** to replace but worth it.
Old Apr 22, 2007 | 03:55 PM
Demolisher's Avatar
Demolisher
so then i have 2 replace both 1/4 window motors lol that sux..
Old Apr 27, 2007 | 02:39 AM
tricci4's Avatar
tricci4
I have found a very simple solution to the problem as I have had this issue in 4 of my ford cars including my 88 Vert. If you remove the window motor, pull the cover off, where the gear is.. you will see probably the remnants of the plastic little cylinders ford puts in the motors to make them work.. unfortunately, they eventually give way and basicly become crumbled garbage. So what you do, is cleanout all the old sludge and replace all 3 of those cylinders with metal nuts (you put the nuts in where the gear has indents. There is a perfect comon size that works.. Im not posive of the size, I think its about a 3/8 or 10mm nut.. very common, that you should have in your house. You cantell if they are the right size if they fitinwithlittle slop. Throw those in with a little grease inthere and you will be good to go. I just did this to my bronco II window motor yesterday.. its free, and last forever (well until the motor actually craps out). If all else fails.. I have 2 rear window motors I can sell ya.[sm=yeahsmile.gif]
Old Apr 28, 2007 | 07:10 PM
Demolisher's Avatar
Demolisher
how much for both and how old are they?
Old May 26, 2007 | 12:36 AM
icemaninlv's Avatar
icemaninlv
Or you can go down to advance or autozone and look in the HELP section and they sell the little white bushings for that motor in sets of 3.
Old May 26, 2007 | 11:51 AM
TwotoneVert's Avatar
TwotoneVert
Hey tricci, got a pic of that fix?
Old May 27, 2007 | 12:07 AM
vt89gtvert's Avatar
vt89gtvert
This is what you need. Simply take the motor out, take the cover off, and you should see the reminants of the old bushings. there are three in each motor, and they are a little bit of a pain to get the new bushings back in (Took me like five minutes for each one). This can easily be done in 30 mins or so, and will save you alottta money. I did it sitting indian style on the driveway, but if you had a table and the like it would be super easy.
http://cgi.ebay.com/ebaymotors/79-95...spagenameZWDVW
Old May 28, 2007 | 05:31 AM
scarslilpyro's Avatar
scarslilpyro
ORIGINAL: vt89gtvert
http://tinyurl.com/ywv8h9
You got any pics of that? Some hoodlem jumped into the car and all his weight went onto the back window and now it does all that you are describing - it still works, but skips while lifting and works with help.
I opened it all up and put it all back but don't want to open it back up unless I am pretty sure I can find what you described.
Old May 28, 2007 | 04:26 PM
vt89gtvert's Avatar
vt89gtvert
This is the best thing I could find as far as a picture, and it isn't much. Basically you take off the cover, and then inside there is literally only one logical place for the three bushings to go. It has been over a year since I replaced mine, but it was pretty simple. It is a triangle inside a circle set-up if I remember correctly, with the three open spots being for the bushings.
