HELP!!!
Old Jun 5, 2007 | 06:19 PM
Stang562's Avatar
Stang562
Default HELP!!!
Well I just finished tinting my windows, so I had to put my top down. Now funny thing is my top goes down but not up.... WHAT THE HELL IS WRONG WITH IT??? I dont want to leavre it like that overnight
Old Jun 5, 2007 | 06:40 PM
GreyStang's Avatar
GreyStang
Default RE: HELP!!!
Ouch[:@]
If U can't figure out what's wrong with the power mechanism, then just grab the top with you hands and PULL it up. So I've heard that is OK to do
Old Jun 5, 2007 | 06:56 PM
Stang562's Avatar
Stang562
Default RE: HELP!!!
I'm going to give that a try... I hope it works
Old Jun 5, 2007 | 08:39 PM
DJPcustoms's Avatar
DJPcustoms
Default RE: HELP!!!
Had this happen to my 88. Would go down fine, but not up due to a loss in hydraulic pressure. Removed the rear seat and sure enough there was a leak somewhere. I couldn't afford to fix it at the time, so usually had to have someone help me "guide" it back up. What a PITA.
Old Jun 6, 2007 | 11:55 AM
Stang562's Avatar
Stang562
Default RE: HELP!!!
So I'm going to need a new motor for it?
Old Jun 6, 2007 | 09:06 PM
DJPcustoms's Avatar
DJPcustoms
Default RE: HELP!!!
ORIGINAL: Stang562
What happens when you hit the switch? If it sounds likes it trying to do something, I would suspect the hydralics. If you hear nothing, then maybe a fuse or motor could be bad, or not getting power for some reason.
Old Jun 7, 2007 | 02:05 AM
Stang562's Avatar
Stang562
Default RE: HELP!!!
When I hit the switch it goes down, but wheb I try to raise it it does nothing... are they separate fuses for each way?
Old Jun 7, 2007 | 03:19 AM
DJPcustoms's Avatar
DJPcustoms
Default RE: HELP!!!
I dont believe so, but when you try to raise it do you hear anything, and does the top make any effort to raise? (even if only an inch or so).
Old Jun 7, 2007 | 12:32 PM
Stang562's Avatar
Stang562
Default RE: HELP!!!
no, it makes no noise, and it doesn't lift
Old Jun 7, 2007 | 02:15 PM
GreyStang's Avatar
GreyStang
Default RE: HELP!!!
So, it opens fine but doesn't close? Geez
What if you open it "halfway" then try to close it? If that works then open it 3/4 way & try to close it.. just as a way of diagnosing the problem
