Inner Rocker Panel Problems
Old Aug 7, 2007 | 02:57 AM
SCHOONER's Avatar
SCHOONER
Default Inner Rocker Panel Problems
Hi Guys
I own a '66 Convert. and this is the first time I am every restoring a car.
My mig welding is good and my cutting out rusty ol' sheet metal is not bad either.
At the present time I have the entire passengers side openned-up. Toqure Box is cut out, Toe Board is out,Floor pan is gone, all the way to the Rear Torque Box is all clear to receiver the new Inner Rocker Panel. HOWEVER!!!
I slide the new I/R/Panel in all the way to the back of the car were its suppose to be.
The problem is: The new I/R/Panel doesn't line-up properly.
What I mean is: Its either high in the back or high in the front. Its not EVEN throuhout, from front to the rear.
I don't see anything blocking it. It just will not sit right where its suppose too.
I order the correct panel, its just won't sit evenly for some reason.
Have any you guys out there have had the same problem. If so, please give a guy some solid suggestions PLEASE.
THANK YOU ALL
GOD BLESS
Schooner [8D]
QUOTE: In life-when your cup is full, STOP POURING.
Old Aug 7, 2007 | 12:16 PM
TwotoneVert's Avatar
TwotoneVert
Default RE: Inner Rocker Panel Problems
Not sure about that. Are you sure your new panel is not warped? Check out the link to the classic forum on this site, https://mustangforums.com/forumid_18/tt.htm, those guys can surely help you out.
GPR
Dec 16, 2015 12:21 PM
copestang
Oct 11, 2015 07:17 AM
uedlose
Sep 30, 2015 08:01 AM
Shawmp
Sep 18, 2015 07:52 AM
2k232
Sep 16, 2015 10:28 AM
