A/C on with the top down?
I've heard of people running the heater in cool weather with the top down, but what about running the air conditioner in hot weather with the top down? Are there any issues with over working the compressor or anything harmful by doing it?
ORIGINAL: remoandiris
In a car with the top up and the A/C set to max (only way I drive), the compressor is recycling air in the car, right? With the top down, it is sucking hot air all the time. Seems to me the compressor is working harder, but I'm not an auto or A/C mechanic, hence the reason for my query.
no, its not any harder on your car - just think about the air its sucking in anyway - the recirculation theory doesnt hold much water. its only bad to use a/c with the windows down in a car with climate control.... in our cars its just stupid, not harmful
ORIGINAL: banned
I use the air with the top down in order to dry my fingers, sweaty from all the work of steering the car, blowing kisses to the chicks, flipping-off the ricers and camaros, and scratching my you-don't-want-to-know.
I'd bet using the air full-on from day one to retirement would shorten its life by maybe 20%. Most of us will never see that point in our cars' careers.
"Ill-advised", "inappropriate", "thoughtless", "non-conformist". Too long to spell, I guess.
I've only used the A/C on hot-rainy-days when the top needs to be up.
But I have used the heater with the top down on cool summer evening drives,,, never thought of using the A/C with the top down, but it shouldn't cause any problems.
The problem of using the A/C "ever" though is, it does rob a lot of horsepower in it's operation.. & I'd rather have more available power instead of being just a "slight bit cooler" on a hot day with the top downlol
Haha, a "slight" bit cooler
This summer we had several 100+ degree days, and I couldn't bear the thought of having the top up, so I dropped the top and cranked the A/C up
Problem solved!
-John
Problem solved!-John
