Certication label on driver door
Old Dec 31, 2007 | 11:08 AM
eekman's Avatar
eekman
Default Certication label on driver door
Just purchased a 94 convertible and had no certication label on door.Need GVW rating, GR Axle weight rating front and rear,and tire pressure front and rear. Can't insure without information.Thanks in advance. Must be from a 94 convertible.
Old Jan 6, 2008 | 01:25 PM
silversol81's Avatar
silversol81
Default RE: Certication label on driver door
Just use the VIN
Old Jan 6, 2008 | 03:08 PM
eekman's Avatar
eekman
Imported into Canada,VIN is not enough.
Old Jan 6, 2008 | 05:39 PM
silversol81
check the owners manual if there is one. you should be able to find this info online.
Old Jan 6, 2008 | 06:38 PM
eekman's Avatar
eekman
Tried online, tried Ford, No manual with car.Hoping someone with a 94 convertible could tell me what is on their door.
Thanks for an answer.
Old Jan 19, 2008 | 11:18 AM
Chuckles_5.0's Avatar
Chuckles_5.0
The tire pressure should be on the tire itself...usually its max 35psi... I've never heard different on street tires.
on the others stuff I can't help...the info has got to be online somewhere...
Old Jan 19, 2008 | 12:04 PM
ryan1994mustang's Avatar
ryan1994mustang
is if a gt or a v6? if it is a 94 gt convertible then i can just copy what is on my sticker. if it is a v6 then the weights are going to be different.
Old Jan 19, 2008 | 09:43 PM
eekman's Avatar
eekman
Sadly it's only a V6 The weight will be different but the rest should be the same. Might be able to find the weight on a convertible here but not many on the road in the winter,The temp today is -42 with the windchill.
Thanks again.
Old Jan 19, 2008 | 09:59 PM
ryan1994mustang
ill go out there in the morning and write it down for you. its sleeting here right now so it would just make it a pain. im sure you wont be able to do much with the numbers until monday anyways. but you may be able to search online for the weight numbers somewhere.
Old Jan 19, 2008 | 11:01 PM
eekman's Avatar
eekman
Thanks, my car is put away till Spring anyway but would like to have the paperwork finished.
Thanks again.
