Top question.
Old Feb 11, 2008 | 03:02 AM
thrty5thsc's Avatar
thrty5thsc
Default Top question.
Hi, everyone!! I just bought an 86 GT Convertable. My top does not work. The guy I bought it from did put new vynil on it but he did not know why it doen't operate. When I hit the top button I do hear the top motor running but the top doesn't move at all. Any ideas would be great!!
Thanks alot,
Joe
Old Feb 12, 2008 | 07:27 AM
ak47dennis's Avatar
ak47dennis
Default RE: Top question.
Silly question...but is it unlatched?
My wife did they same thing once
Old Feb 12, 2008 | 07:59 PM
thrty5thsc's Avatar
thrty5thsc
LOL... Yes it is. I wish that was the case.
Old Feb 12, 2008 | 08:09 PM
ryan1994mustang's Avatar
ryan1994mustang
your lift cylinder might be bad. one of the seals could be worn and broken, and not allowing it to build up pressure to move the top. can you raise/lower the top by hand??
Old Feb 12, 2008 | 11:20 PM
thrty5thsc's Avatar
thrty5thsc
Yah, Everything seems to move ok.
Old Feb 13, 2008 | 11:36 AM
ryan1994mustang
if you can raise and lower it by hand then there is prob something wrong with the lift cylinder. it should have built up pressure in it and not really allow it to move. check to make sure everything is hooked up right, or it could be something inside the cylinder.
Old Feb 13, 2008 | 08:21 PM
thrty5thsc's Avatar
thrty5thsc
Ok, I'll look into it. I did put it down easily. Lifting it up was a little more difficult.
Old Feb 14, 2008 | 08:18 AM
ram2sak's Avatar
ram2sak
the mounting pivots on the lift cylinders are made out of plastic that gets brittle with age
look behind the 1/4 panels, in the back seat ,with the top up to see if the pivots are secured to the frame if they are the fluid has leaked out somewhere or the pump isnt making any pressure
Old Feb 14, 2008 | 05:19 PM
thrty5thsc's Avatar
thrty5thsc
I'll check that tomorrow. Thanks for all the help. You guys are great!!!
Old Feb 19, 2008 | 09:05 AM
thrty5thsc's Avatar
thrty5thsc
Ok, The cylinders seem to be attached ok. the lines also feel tight. I used to have a nissan 240sx convertable, and I could see fluid in the lines. On my Mustang I really don't see it. I assume the lines are probably the same. Where do I check the fluid? is it the phillips head screw on top of the pump? The revs up real good. Sounds like it may be empty. When I hold the button it seems to spin faster and faster.
Thanks alot,
Joe
