MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Convertible Tech (https://mustangforums.com/forum/convertible-tech-78/)
-   -   Top won't move at all. (https://mustangforums.com/forum/convertible-tech/471453-top-wont-move-at-all.html)
pbMaxLax44 Aug 5, 2008 09:27 PM
All of the sudden my top won't work on my 2000(earlier edition) 3.8. It's not the convertible top fuse under the dash, it's perfectly fine. When I push the button I can hear a faint click towards the back of the car but nothing happens. Yes I am doing it properly, I have been for 4 months. What could be wrong?
drew50 Aug 6, 2008 11:57 PM
RE: Top won't move at all.
Have you checked all the electrical connections? Maybe its something like that. Hope you figure it out.
pbMaxLax44 Aug 7, 2008 01:08 PM
Not yet, today I'm about to take it all part and just follow the button all the way back.
chicobob Aug 11, 2008 01:48 PM
I have a 2006 convertible and had the same symptoms about 3 months into owning it. Not sure if the process is the same on your model but I was able to find a hydraulic pump in the trunk pan and see that it was blowing fluid all over the place. Turns the whole thing needed to be replaced. Might be something to look for...
remlle Aug 17, 2008 08:43 AM
If you hear a click Im betting you hearing the relays clicking in. I have an 89 GT Vert and it did the same thing. I could hear the relays click in but no motor. the motor brushes were shot and caused the motor to stop turining. I took the motor out of the houseing and could see it was bad. smelled burnt and all. I went to a classic mustang place and got a new pump and it worked. fixed my issue. it was close to 300 bucks. but I know on ebay there are a ton of used ones. might be worth checking into.
© 2026 MH Sub I, LLC dba Internet Brands
