04 vert motor fluid
Old Jul 14, 2013 | 04:04 PM
FlamingoGT's Avatar
FlamingoGT
Default 04 vert motor fluid
My top is not wanting to go down very well on its own, and going up is extremely slow... could this be a sign of low fluid? If so, what kind of fluid is used in the stock pump, and where is the fill plug?
Old Jul 15, 2013 | 04:45 PM
Special20's Avatar
Special20
After removing the top and bottom rear seat, you should see the pump mounted in between your amps. The black fill plug is on the right hand side of the pump. I was able to bend the relays out of the way to get to the plug. Pull the plug and fill until the fluid flows out of the plug hole. The top should be down(open) for this. If it is low, you have a leak. Look at hose connections to the rams and to the pump itself. Also, look around where the the arms go into and out of the rams. You may have to pull the rear speakers to see if there is any fluid dripping to the rear floor boards. Convertibles are great but there is a little more involved in maintaining them. Good luck.
Old Jul 15, 2013 | 06:09 PM
FlamingoGT's Avatar
FlamingoGT
Thank you for your help.
What kind of fluid? ATF?
If it is a leak, it is a slow one. It has lasted 10 years. I will need to get a new top soon enough if I keep this car (I want to, but it is starting to nickle and dime me).
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
Sep 25, 2015 06:42 PM
