2000 Convertible frame Coupe vs GT
Old Feb 17, 2017 | 03:19 AM
Rich63's Avatar
Rich63
Question 2000 Convertible frame Coupe vs GT
Can a 2000 Mustang Coupe Convertible frame be put into a 2000 Mustang GT? Are they interchangeable?
I have found a garage kept 2000 Coupe Convertible top and I would like to put it in my 2000 GT.
Has anyone done this before?
Old Mar 6, 2017 | 04:30 PM
Rich63's Avatar
Rich63
The frame fit perfectly. The motor and hydraulics worked fine for 3 days. NOW, the motor will not even make a sound. Does anyone have any thoughts why the motor would work one minute and not the next?
I have checked all fuses and they are good. I did a continuity test on the switch and it is good. I have bled the system manually (twice), and finally got the motor to put the top up but... and you probably knew that was coming... the motor stopped again. I am not sure why but while the top was fully extented, I kept hitting the button (cuz I needed every inch out of the stretch) which may have put the motor in a bad position. Is that possible? So, I did what worked before, I manually bled the system but still no motor activity. Is there any pressure sensors? It doesn't look like there are. Only relays to activate the forward/reverse action.
