Clay bars
Old Mar 20, 2006 | 12:26 AM
97BlackStang's Avatar
97BlackStang
Default Clay bars
What exaclty does a clay bar do? How do I apply it, and remove it. Does it require special skills?
The stang needs a good cleaning and waxing it looks like ***. It needs all the help it can get. I want to get that glossy wet look, or as close as i can.
Old Mar 20, 2006 | 01:24 PM
shayne's Avatar
shayne
Default RE: Clay bars
Clay will work wonders when used correctly and before a 3 step system.
Check out autopia.org and autogeek.net
Old Mar 20, 2006 | 07:40 PM
MustangChris04's Avatar
MustangChris04
wash your car, then use put soapy water on the area you want to clay bar and rub the bar back and forth. All the junk will stick to the bar. Then when you dry it you can feel the car and see that it is completly smooth.
Old Mar 20, 2006 | 09:18 PM
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
do you usually do the whole car and how often do you clay bar it?
Old Mar 21, 2006 | 08:32 PM
langod's Avatar
langod
You should only have to clay your car once a season -- maybe twice if it gets a lot of contaminants. The clay smooths out the finish and pulls microscopic embedded crap out of the finish. Go to www.autopia.org or www.autopia-carcare.com (both the same site) for a full guide on cleaning your car really well.
Old Mar 23, 2006 | 02:32 AM
94Cobrakid16's Avatar
94Cobrakid16
dont use soapy water tho, buy a kit(20$) it comes with a spray thats made to be used with the bar, and mine came with a 5oz or so bottle of wax.
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
Sep 16, 2015 07:53 PM
