Weird question I guess?
OK, i have an '02 GT.. when I open up my trunk, there's like a little canyon that borders the, um, border of the trunk. A lot of dirt and crap gets stuck in there. Any suggestions for cleaning that? I would squirt it with a hose and clean regularly, but I don't want to get water *in* my trunk.
thanks!
thanks!
Use your hose without a nozzle, and turn the spigot on to a low pressure setting. Wet down the "canyon", then use your wash mit to clean it good, then rinse with the same method as above. If you get the trunk wet, just leave it open overnight to let it dry - or leave it open in the sun and set a small fan in there to speed up the process.
Once you do this, you should be able to only wipe it out with a wet towel every time you detail the car to keep it clean.
jaiidutch
Sep 14, 2015 10:29 AM
