Fire from exhaust
Old May 21, 2003 | 11:56 PM
sizerman's Avatar
sizerman
Default Fire from exhaust
Does anyone know how to make fire come out of your exhaust?Thanks for any info!!I I have a 91 mustang LX 5.0with flowmasters and no converters.
Old May 23, 2003 | 07:29 PM
stanglover's Avatar
stanglover
http://www.studz.freeserve.co.uk/creatures/flame.htm
Be careful though, l heard the flames can go backwards and you'll have fire going into the engine.
Old May 25, 2003 | 05:35 PM
ECR5.0's Avatar
ECR5.0
its dangerous...and probably not even worth doing...put the money into making your car faster...screw the flames
Old May 27, 2003 | 01:29 PM
MustangGTRocks's Avatar
MustangGTRocks
Yeah, it's not worth it!
Old May 27, 2003 | 09:26 PM
03SVTcobraa's Avatar
03SVTcobraa
I don't see the purpose, other than it is kinda cool to see that, but personally I wouldn't waste my time or money on that mod. Make your car faster like ECR5.0 said.
Old May 29, 2003 | 11:01 AM
sizerman's Avatar
sizerman
Thanks for the suggestions!<IMG src=smileys/smiley16.gif border="0">
Old Jun 1, 2003 | 05:56 PM
Sicy Stang's Avatar
Sicy Stang
Wow that's scary! <img border="0" src=smileys/smiley3.gif border="0"> I dont think I would ever do that.
Old Jun 2, 2003 | 02:38 AM
jeep45238's Avatar
jeep45238
I ♥ Acer
Easiest way:
Weld a bung for a spark plug in each exhaust tip.
Weld a bung for a jet (like a nitrous jet) approx. 6" infront of the spark plugs.
Run an ingnition coil to each spark plug.
Run a line from the jets to a bottle of propane, using a silinoid like those of nitrous kits to control the flow (on or off) of the propane.
Run power to the ignition coils and to a switch, a switch for the silinoids, and a failsafe that cuts ignition and the propane off (saftey). When it's all goin...you have fire.
It follows the same princibles as a propane grill.
Old Jun 2, 2003 | 02:41 AM
Sean's Avatar
Sean
I heard that will not work with cats,true?
Old Jun 3, 2003 | 11:16 PM
sizerman's Avatar
sizerman
I don't have cats!! I heard u can just install sparkplugs and run a wire to the coil and put u a switch inside to fire the plugs. do u have to use propane or can it fire off the fumes from exhaust?
