Your painted interior
Old May 15, 2006 | 06:21 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: Your painted interior
as long as you clean it up really good you should be fine. ive had mine for a long time and its still looking good
Old May 15, 2006 | 07:17 PM
Mustang_Ali's Avatar
Mustang_Ali
Ok, coming from me who does interior dye work every day, you will atleast want to sand it down. Painting over those cracked areas, it won't cover well and you'll see the imperfections. You should be good to go by just sanding it. I would use like 800 sandpaper. The primer you use will kinda make or break it. That's what gives the dye something to adhere to, it's the base. I can't give any recomendations, the base and top coats I use are specific to my company, not available to the public.
Hey Britt21, it's an extremely simple process. As long as you remove each trim piece, so you don't get overspray on anything else, properly clean the pieces before paint, you'll be fine. Be sure to clean the pieces though, if you don't, the paint might not adhere because of the oils on the trim pieces, then it'll be screwed up.
Old May 15, 2006 | 08:05 PM
StangGTao's Avatar
StangGTao
If I sand it down when will I know when I will be able to paint?
Old May 15, 2006 | 09:24 PM
live4motocross11's Avatar
live4motocross11
just sand it down and wash off all the dust particles and then spray ur primer and it should say how long to wait for another coat, then it should say how long it takes to dry, then the paint should b the same, as with clear
Old May 15, 2006 | 11:28 PM
Mustang_Ali
For painting those trim pieces you should clean them off with rubbing alcohol, I'm pretty sure that's what they suggest using. You won't need to sand much, but you might need to do more because you said it's cracking. Just sand until it feels smooth and even, and until there's no more cracks. The plastic trim pieces don't have much of a grain, they are only slightly textured, so don't worry about it being too smooth.
Old Jun 7, 2006 | 03:51 AM
sparkomatic's Avatar
sparkomatic
that is exactly what I would like to do with my 'stang...what type of paint did you use? My issue is that I have the electric green.
I have seen several painted interiors and too often I think they get carried away, but to me, that is just right.
thanks for posting pictures
cheers
Old Jun 7, 2006 | 11:17 AM
yellowjacket01's Avatar
yellowjacket01
i sand blaster all my interior pieces in a bead blaster and they came out perfect didnt have to prime,used engine paint though cause the fusion paint i had before got darker as the sun hit it.If anyones interested if you want to send me your interior pieces i can bead blast them and send them back..just incase you dont feel like sanding.
Old Jun 7, 2006 | 03:24 PM
LEJAY's Avatar
LEJAY
I ♥ Acer
I dunno to each his own. But, consider.... Where did all this interior paint and color come from ?
RICERS
JMO
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
GLOCKer
Sep 28, 2015 07:36 AM
treesloth
Sep 28, 2015 07:03 AM
