about to detail
Old Jul 1, 2006 | 12:23 AM
mustanggt2002's Avatar
mustanggt2002
I ♥ Acer
Default about to detail
hey i am about to detail my black car, i have minor swirls in the paint and some minor scratches. i have a claybar and paint cleaner, will a polish do the same thing as a swirl remover? i have scratch X but it dosent seem to do too much, what would you suggest? try the scratchX over the entire car or what
Old Jul 1, 2006 | 05:22 AM
Jim D.'s Avatar
Jim D.
Default RE: about to detail
"Polish" and "Swirl Removers" are typically very similar products... knowing the brand of the product would be helpful, as what one company calls a polish might not be what another company calls a polish -- but most importantly, is it the product you need for a particular task.
Knowing what "minor swirls" are and how they got there would be helpful. Swirls caused by improper use of a machine could be a real problem. If you have common spiderwebbing from improper washing and/or drying, those are easier to address.
If you have access to a high-end consumer machine (defnintely not the $20 jobs) or a commercial-quality Porter-Cable, try a polish (I like Mothers Power Polish and a good pad) to remove the swirls and scratches.
If you plan on doing it by hand, I'd perhaps go this method: use a scratch remover in varying directions to help work-out the deep scratches. Then over the whole car, do the clay, pre-wax cleaner (probably the cleaner you have is fine), sealer & glaze (this step helps to fill and hide those light defects), and then pure carnauba (to protect). Again, I like the Mothers... what they call their 3-step Ultimate Wax System, though you usually get the products separately. Next time you only need to do one or two steps; the full-on treatment should only need to be done once or twice a year.
Though you may be able to get satisfactory results with a cleaner wax product or perhaps skipping a step or two. You've got to "rejuvenate" a little and it should be easier to maintain in the future.
Another alternative.... I've seen a black show car with the Mothers Sealer & Glaze (which will help with spiderwebbing) followed by their Reflections Car Wax (which has mild cleaners and a nice synthetic) -- incredible results. But you'll still need to do something about those larger scratches -- if they're too deep, you may have to live with them.
There are some write-ups at http://www.detailguide.com that you might find helpful.
JoshyGT
Sep 19, 2017 08:52 PM
KingRando
Oct 2, 2015 08:06 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 17, 2015 07:57 PM
Oak
Sep 14, 2015 03:08 PM
