Headlight pitting
Old Aug 3, 2006 | 11:07 AM
jes72mustang's Avatar
jes72mustang
Default Headlight pitting
The headlights on my 02 GT are starting to look like someone took a sand blaster to them. IS there anyway to polish them to help make them more clear again rather than just replace them?
Old Aug 3, 2006 | 12:42 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: Headlight pitting
Go to any auto store that sells Meguires and try their Clear Plastic Polish. I've used it on scratched domes of cctv cameras and it works great. Its listed as being for plastic head/tail lamps! Use a lot of elbow grease and it should do the trick. If they are REALLY bad and the "hand job" doesn't do the trick, you may have to invest in a rotary polisher and use a plastic polishing buff with that Meguires polish.
Check out http://eastwood.resultspage.com/sear...33&submit.y=11 for more details
Old Aug 4, 2006 | 02:32 AM
rsk1390's Avatar
rsk1390
so that might get rid of that crusty/hazey look to 'em?
Old Aug 15, 2006 | 02:58 PM
jes72mustang
Thanks I will try the Maquires route first.
Old Sep 8, 2006 | 04:20 AM
V6madman's Avatar
V6madman
I tried the Maguires and it did a little to help the haze, but not nearly what I was hoping for. I even took it to a body shop owned by a buddy of mine and they used a compound designed specifically to buff out headlights and their high rpm buffer and it did a great job, but there were some places that just refuse to come unhazed. I've heard wet sanding can help too but I don't want to try it until I've heard some feedback from people that have tried it. Has anyone here?
Old Sep 8, 2006 | 04:32 AM
BleedinBlue's Avatar
BleedinBlue
I wetsanded one of my headlights, which was very hazy. It cleared it out VERY well, probably took it from about 30% clear to 85% clear. The process does remove all of the clearcoat from the light. I tried to put a new coat of clear on, but I'm either a lousy painter or I bought some bad paint, it went on with a whitish tint. I then just sanded that off and said the hell with it. I just put several coats of wax on instead. I did not use a good electric buffer afterward, if I had, I think it would probably look like new.
BTW, I was afraid to sand the lights too, I bought a new set and sanded the spare. I have the old set for sale, btw.
Old Sep 9, 2006 | 05:12 PM
NaplesFL11GT's Avatar
NaplesFL11GT
I bought the Meguiars plastic cleaner also and it did little to clean up my lights. Looks like the haze is on the inside of the light. Im thinking about buying new headlights.
Old Sep 10, 2006 | 12:06 AM
BleedinBlue
ORIGINAL: NaplesFL03GT
Thats what I thought about my old lights too, until I wet sanded them. Like I said before though, the haze is gone, but the gloss from the clear coat is gone also.
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
