clay bar ???
Old Sep 27, 2006 | 07:25 PM
99 GT vert's Avatar
99 GT vert
Default clay bar ???
i was reading up on this process but i was just wondering a little more on what it does and how u do it and if it will damage the car if you mess up or if you can do to much at once and start to strip the paint off
Old Sep 27, 2006 | 09:09 PM
ZAXJAX's Avatar
ZAXJAX
Default RE: clay bar ???
It's really idiot proof. As long as long have enough lube on, you're fine. You'll tell when you don't, you will feel a pull or the clay gets stuck. This is assuming your using a mild clay. I have never heard of anyone pull paint off.
Old Sep 27, 2006 | 09:17 PM
LilDerk86's Avatar
LilDerk86
IO details at work all day and we use a clay bar a lot. To me it works wonders to get off tar, overspray, and just about anything. It really helps get the car a lot cleaner. i would recomend it to anyone really. And I have never seen one damage a car.
Old Sep 27, 2006 | 11:32 PM
Juztang's Avatar
Juztang
The only way it would damage a car is if you dropped it on the ground. I like to break the claybar up into 3 pieces. Use one to clay and put the other ones in a container. That way if you drop it you can use one of the other pieces. If you dropped a whole claybar you basically wasted the whole thing.
Old Sep 28, 2006 | 10:29 AM
99 GT vert's Avatar
99 GT vert
ok thanks i justa wanted to make sure that i could not damage my car if i did something wrong i will probly go buy some after school
Old Sep 28, 2006 | 10:57 AM
AJ06GT's Avatar
AJ06GT
Yeah, you're not going to damage your car but you are going to strip off the wax by using it, so if you plan on doing it after school today, plan on waxing the car after you finish.
Old Sep 28, 2006 | 11:03 AM
99 GT vert's Avatar
99 GT vert
ok thats what i read how many times can you get with one bar and i should probly wash the car before i do this process
Old Sep 28, 2006 | 12:33 PM
Scott P's Avatar
Scott P
ORIGINAL: 99 GT vert
Break/cut the bar into three pieces before you use it. One piece should be enough to do your car a few times. If you drop it on the ground, throw it away and graba new piece. You will want to wash the car beforehand. You don't need to wash it afterwards.
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
Sep 16, 2015 07:53 PM
