Removing paint "rub"
Old Nov 3, 2006 | 12:39 AM
CrazyAl's Avatar
CrazyAl
Default Removing paint "rub"
OK,
as a result of a stupid parking lot incident, there is some "damage" to the paint on my passenger's side front fender. As best as I can tell, my paint is unharmed but some of the other guy's paint has transferred itself to my car. It looks like this paint residue could simply be buffed off. There are no dents or scratches that I can see, just this "paint transfer".
Any tips on how to do this?
I'm a very competent mechanic but I'm no body guy...
Old Nov 3, 2006 | 12:46 AM
Ken M's Avatar
Ken M
Default RE: Removing paint "rub"
I use Turtle Wax rubbing compound, the type that is "safe for clearcoat". It usually removes 99% or more of the paint transfer. I've used it many times for this purpose. Always rewax the area.
Old Nov 3, 2006 | 12:50 AM
Juztang's Avatar
Juztang
I would start out with a light abrassive polish. If that doesn't work move up to a medium abrassive. I deal with this kinda thing a lot. Sometimes you can remove by hand and sometimes it requires a buffer. It is really hard to tell without me seeing it. As long as you can feel any scratches with your fingernail it isn't into the paint and can be buffed off. Do you own any polishes?
Old Nov 3, 2006 | 11:11 AM
CrazyAl's Avatar
CrazyAl
I have some Never-dull chrome polish (cotton wadding type) and I have two different waxes. I have Zymol I use on the 'stang and I also have some 3M Show Car wax that I use on my motorcycles.
I also have some 3M "General purpose adhesive cleaner". I use this stuff to remove tar and other "sticky stuff". A buddy of mine that used to work in a GM dealership said they used to use this stuff all the time to remove paint marks, so I have considered trying it, but I thought I'd ask around first.
That's the extent of my cleaning/detailing products. I don't own a buffer.
Old Nov 3, 2006 | 04:42 PM
Juztang's Avatar
Juztang
I have Poorboys SSR1 light abrassive that should remove what you are talking about. I also have the medium abrassive SSR2.5 that is a medium that would also work.
If you wanted to go over the counter. Megiuars Scratch X might work.
Old Nov 4, 2006 | 12:46 PM
Ken M's Avatar
Ken M
Correction, it's Turtle Wax "Polishing Compound" (not "rubbing compound"). Always has worked great for me.
Old Nov 6, 2006 | 10:39 AM
CrazyAl's Avatar
CrazyAl
I snagged some of the turtle wax polishing compound over the weekend. I'll give it a shot today and report back on my success.
Old Nov 6, 2006 | 01:14 PM
Jim D.'s Avatar
Jim D.
If there's any chance to get a "bite" on the edge, you could also try a clay bar... it's likely safer than polishing.
I guess I should say that pictures would be helpful, but it sounds like you've got some good tips already. If you've got some cleaner wax, that'd be a very safe start.
Old Nov 6, 2006 | 01:57 PM
wingman75's Avatar
wingman75
ORIGINAL: CrazyAl
I have had success using NuFinish Scratch Doctor, clearcoat scratch remover on my white Dodge to remove a paint rub like you describe. I don't know how it would work on a black car though. Just another idea.
Old Nov 6, 2006 | 07:01 PM
xpreshun's Avatar
xpreshun
I use the turtle wax polishing compound, but only for medium jobs. It is a bit more abrasive than would appear. For jobs like what you are describing I have actually found the best thing to start with before the turtle wax polish is "Kit Scratch Remover." It is around $3 at Wal-Mart, and it takes off not only paint rubs, but also light scratches, accidental swirl marks if you get something abrasive in your power polisher/waxer/buffer, and also abrasion scratches from a person walking by the car. It is safe enough to use on a power waxer/buffer for larger areas on older cars, etc. If it doesn’t get all of it, then go to the polishing compound. Good luck.
