air compressor
Old Nov 17, 2006 | 12:38 AM
5.0 FanAddict's Avatar
5.0 FanAddict
Default air compressor
I want to start painting small pieces under the hood here and there and maybe some interior panels and try and to learn how to paint
will this compressor work for that job, Im not going to paint a entire car so Im thinking this will work
http://www.dewalt.com/us/products/to...productID=2952
Drive Direct drive
Horsepower 1.2 continuous HP / 2-3/4 Max HP
Tank Size 4 single ASME tank gal
Power Supply 120V AC, 15 amps, 60 Hz, 2 pole induction motor
CFM @100 PSI 4.5 CFM
Pump Speed 3400 rpm
Tool Length 21.75 "
Tool Width 23 "
Tool Height 12.5 "
Tool Weight 61 lbs
Shipping Weight 71.25 lbs
Includes: DEWALT Synthetic Compressor Oil
2 universal quick couplers
regulator
Old Nov 17, 2006 | 05:34 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: air compressor
I don't see why it wouldn't work. I see trim carpenters spraying stain & lacquer all the time with smaller/portable comps like that. It will just run more often then a larger tank compressor. I haven't painted with a compressor for a long time so somebody else can chime it on this - but I THINK you only need about 40 psi to run a spray gun.
BUT you may want to consider a bigger unit that goes upwards of 140-150 psi. You will want to start using it for other odd jobs around the house and you might find the 100psi to be limiting - such as removing over torqued or rusty lug nuts, removing the lawn mower blade, other similar large nuts via an impact wrench, shooting nailes through your skull (just kidding [8D])
Lethaldosage423
Oct 19, 2015 12:12 AM
Dokilar
15
Oct 16, 2015 08:13 PM
fastbackford351
Oct 1, 2015 12:24 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
