HID Headlights
Old Dec 8, 2006 | 01:42 AM
axcelp_15's Avatar
axcelp_15
Default HID Headlights
Hey guys i have a 90 mustang gt and I was wandering if there is any way possible for me to install some bright HID lightbulbs? Now I have multiple questions first is it possible
being that the car is old. next, will i have to buy new headlights that can support HID lighbulbs because i hear these bulbs go with only special kinds of headlights that can support
the power of the HID's. I've hard that the factory headlights might bust is that true? if anyone please tell me what i should do. thanks i really appreciate the help.
Old Dec 8, 2006 | 03:39 PM
JohnnyAce's Avatar
JohnnyAce
Default RE: HID Headlights
Axcel,
First off, I'm guessing you want the HID look with just regular bulbs. If thats the case, check out the slyvania silverstar line or others that say XENON. Be careful though as some of these bulbs run a higher wattage to give the brighter light. This increases the heat output of the bulb and MAY cause damage to your headlight housings. This is where you have heard it might cause them to bust.
Now, you cannot just buy a true HID bulb and use it. It requires a ballast and ignitor. HID bulbs contain xenon gas and NO filament. The ignitor causes an arc through the gas which gives you your light. A true HID conversion is fairly espensive too. Check out www.xenonking.com Poke around that site, especially the FAQ, it may answer some of your questions.
Good luck
John
Old Dec 8, 2006 | 05:27 PM
tommy2273boy's Avatar
tommy2273boy
HID kits are StangMods.com bread&butter.
send him a question in the Vendors forums section,
or send 'em a PM, he replys really fast!
gl in shopping.
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
kawiguy827
Sep 22, 2015 10:52 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
