Cleaning a Car Cover
Hey guys,
I've got a Wolf Car cover, one of those ones thats water resistant, ding resistant, uv protection, and all that good stuff. Its like a $300 cover and i'm trying to figure out a safe way to wash it. someone told me you can't run them thru the wash machine. i can't find directions to safely wash it. let me know what you guys think.
thanks, Nick
thanks, Nick
Washing machines are pretty dangerous - and NEVER put it in the dryer. Is it dirty both inside and out? If so put it on the car inside out and wash it with some mild detergent and a wash mit like you were washing the car. Rinse it off GOOD, then put it onright side out and do the same to the outside fabric. When done, leave it on the car for a day in the sun so it can dry out good. Obviously you will need to do this in the AM on a good sunny day and have other transportation available
If you don't rinse the underside off real good then be prepared to have to wax or at least detail spray your car.
A home top load washer can be very hard on a car cover, in part due to its bulk.
If it's washable at all, I've had good luck the large front load washers at a laundry mat, and dry on low heat (inspect regularly and re-arrange as necessary).
NO TO THE DRYER!!!! Trust me. The fabric will melt and then you're hosed [:@] Even on NO HEAT setting like mine, it still got a tad warm and apparently the friction didn't help things. Air drying is the best thing. If it is machine washable per the instructions then you will need to go to a laundro mat as mentioned for the size of the washer.
Thanks for the input guys...I am going to probably try to contact the manufacturer as well, but i couldn't find any info online anywhere except here.
thanks, Nick
thanks, Nick
inyadreems
Aug 21, 2015 09:10 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
