decklid
i removed my rear spoiler then clayed and 3 stepped my decklid...well when i took it off there were dirt rings from where the spoiler met the deck lid...i wiped my finger across them a couple of times and decided not to do it anymore because if i was dirt i didnt want to scratch the paint and because i thought it may have been grease that was keeping the spoiler from scratching the paint...well now its dryed clayed and 3 stepped and the rings are still there...acutally i didnt clay over the rings or 3 step them because i did not want to leave scratches...so how do i get the rings out without leaving scratches? also, to fill in the holes that the screws left in the decklid, what can i use? i was gunna use rivets but i dont want to leave little circular scratch patterns...thanks!
Bill
I would wash the area and claybar it first. Then use a mild polish to remove the rings. If that doesn't work step up to a more abrassive polish. Can you feel the rings with your fingernail? If they aren't into the paint they should come out.
To fill in those holes I recommend taking it to a body shop and have them do the work.
ORIGINAL: Juztang
Bill
Bill
] can it be?! ill get some pics up if you needP.S. after i finish getting my stupid paypal accnt set up im buying some of your waffle weaves
and maybe some glazzzzeee
So you are saying the dirt is hard and won't come off after you wash it? I think I know what you are talking about. You might try some WD40 to loosen it up a bit and see if that works. If not, like you said the spoiler will be back on to cover it up.
You actually don't need a paypal account to order from my website. It also takes credit and debit cards.
ORIGINAL: Juztang
when it was "wet" right after the spoiler was just removed, minutes after...i swiped my finger across it and theres a clean spot now where my finger was before...it was really thick thats why i thought it was protective grease or something....how should i use the wd? just spray a little on there, let it sit for a couple of minutes and wipe off? if that doesnt work, what else can i use? thanks
I think the WD will do the trick. Just let it sit for a few seconds and then wipe off with a microfiber. Then just go over it with a polish or cleaner wax. I've taken spoilers off of carsthat I detailed before car shows and know what you are talking about.I really just think it is probably a buildup of dirt and grime right there from what I've came across. Iusually just wash the area and then if needed use something to break up the residue.
MustangJourney
Sep 2, 2015 04:32 PM
sharkbite1979
Dec 29, 2005 03:42 PM
sharkbite1979
Dec 29, 2005 02:47 PM
