Rusting rock chip
Old Apr 27, 2007 | 03:31 AM
BleedinBlue's Avatar
BleedinBlue
Default Rusting rock chip
I was washing my car the other day and on the top of my car I found a single rock chip that is rusting on the inside of it.
If I cover the chip with touchup paint will it stop the spread of the rust? The paint around the chip looks perfect, so I don't want to sand and make it worse and actually noticeable.
Old Apr 27, 2007 | 11:41 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: Rusting rock chip
How long has it been there? Are you sure its rust and not just the primer? I would guess if it is fairly new you are just seeing some simple surface rust starting. You should be able to get a chemical rust remover and dab in there to clean it up before touching it up. I wouldn't think it would cause any future problems.
Old Apr 27, 2007 | 07:45 PM
BleedinBlue
ORIGINAL: sowaxeman
I'm sure it is just surface rust, but it is definitely rust. I'll try some of that remover, I had forgot about it until now, but I know I have seen it.
Old Apr 29, 2007 | 06:58 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
After the rust remover go ahead and touch up the chip to prevent future rust from returning...I am sure you knew that though.
b8checker
Oct 8, 2015 12:55 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
b8checker
Sep 30, 2015 07:11 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
