help
Old Jun 25, 2007 | 03:54 PM
thatdude305's Avatar
thatdude305
Default help
not sure how to wax 1st i wash the car then wax it?? correct??? the wax i have i mothers carnauba cleaner wax is that any good?? is that the ciorrect wax???i bought a pack of micrfiber towels ( 3 towels)..are those ok to use and do i have enough of them??do i put the wax on in a circular motion then wipe immediately or let it sit..i really want to do this im just not sure...help me out ladies and germs
Old Jun 25, 2007 | 04:31 PM
rogan01's Avatar
rogan01
Default RE: help
I'm sure others will respond - you can also go to the autogeek detailing website - they have lots of guides.
Yes - first you wash then wax for the most basic detailing. You should apply the wax with an applicator - microfiber or cotton. It should have instructions on how to apply. Sometimes using a circular motion leaves swirl marks - depends a lot on the color of the car - darker colors show swirl marks more. I use overlapping staright strokes. Microfiber towels are recommended for wiping off - usually do one section at a time - when it dries - buff off with a micofiber towel.
Like I said - this is very basic - lots of more detailed info and opinions on this forum and online.
Good Luck!
The wax you have is probably fine but there are lots of products and LOTS of opinions about which is best. That should get you started with what you have - hope it helps.
Old Jun 25, 2007 | 04:36 PM
thatdude305
Default RE: help
so what should i apply the wax with then if not a microfiber towel
Old Jun 25, 2007 | 05:21 PM
Juztang's Avatar
Juztang
Default RE: help
I like to apply wax with a foam applicator. The foam doesn't absorb the product as much as terry cloth applicators and your product will go further. I carry some 6x4 foam applicator pads that work great for applying polishes,glazes,sealants, and waxes.
For taking off products and drying microfibers are the way to go.
If you are looking for a good wax that is easy to use you should check out my Wet Wax. This goes on easy and comes off easy. My wax doesn't have any residue and can be used in the sun.
Old Jun 25, 2007 | 05:33 PM
thatdude305
Default RE: help
how long do u take to ship??
Old Jun 25, 2007 | 06:17 PM
Juztang's Avatar
Juztang
Default RE: help
Most of the orders go out the same day.
Old Jun 25, 2007 | 07:58 PM
Tay0627's Avatar
Tay0627
Default RE: help
Hey juztang...i think you've told me this before...but...my car is black. I'm about to order teh PC package with the poorboys. What else do I need...as far as sealent, wax, detailer.....and so on. is there a package that is better for me? thanks
Old Jun 25, 2007 | 08:13 PM
Tay0627's Avatar
Tay0627
Default RE: help
i found the answer.....had to dig a little but i found the post where you'd already gone over this. thanks.
Old Jun 25, 2007 | 08:15 PM
Juztang's Avatar
Juztang
Default RE: help
ORIGINAL: Tay0627
Wanted to let you know that my new line is now out. You should really look into the Wet Glaze and Wet Wax for your color. Also check out my new Fast Shine and Waterless Wash Quick Detailers. They have been a huge hit!
Old Jun 26, 2007 | 02:53 PM
thatdude305
Default RE: help
juztang your stuff better be good or i want my money back
