scratches
i have a bunch of little scratches on my car all over the place...has anyone ever tried that nu finish stuff...does it work...is there anything else out there that some1 could recommend....help me out boys and bitches
When you use a product like Scratch X, can you use it just over the minor scratches or is it best to use it over the entire car or panel?
Also, can it be used over top of existing wax, or should all way be removed first before applying?
I was gonna post the same. I removed this stupid strip like a door guard on the side and I f****d up on the drivers side door. The scratches aren't deep enough that you can feel them with your nail, can that still be buffed out? I have white so I can hide it with wax, glaze and a polish. But I don't want to see it at all. Should I try Meguires Scratch X or buy a buffer?
The Porter Cable is the way to go if you want to remove scratches and swirls and not have to worry about hurting the paint. The Poorboys Super Swirls Removers work excellent and the Optimum is works great but it is designed more for a novice.
