How do you?
Old Jan 13, 2005 | 02:26 PM
StangGT804's Avatar
StangGT804
I ♥ Acer
Default How do you?
Well when i bought this car it has the dealerships sticker oon the rear of the car, right underneath the GT badge. How do i get it off safely?
Old Jan 13, 2005 | 02:29 PM
xRockThePonyx's Avatar
xRockThePonyx
Default RE: How do you?
Take a blow dryer and heat the sticker, then gently peel it off. After you remove it, there may be some goo from the sticker, which you can get off with any type of Goo Gone type stuff.
Old Jan 13, 2005 | 02:30 PM
StangMang's Avatar
StangMang
Try Goo-Gone...but read the back of the bottle about car apint...
might work??
Old Jan 13, 2005 | 02:46 PM
StangGT804's Avatar
StangGT804
I ♥ Acer
ok thanks for the quick help!! Ill try the blow dryer n wont it come off with jus rubbing alcohol??
Old Jan 15, 2005 | 03:47 PM
SShadowSSin's Avatar
SShadowSSin
Is rubbing alcohol safe for paint? I"ve never used it on paint.
Old Jan 15, 2005 | 04:36 PM
Dan04COBRA's Avatar
Dan04COBRA
ORIGINAL: StangGT804
Blow dryer will work just fine, use tar & bug remover to get any of the glue off.
Old Jan 15, 2005 | 08:54 PM
xRockThePonyx
I've never heard anything about rubbing alcohol. I wouldn't take the chance on the paint though, it may cause discoloration or something. Try the blow dryer first, then if that doesn't work, I guess it's worth a shot.
Old Jan 16, 2005 | 02:57 PM
code3GT's Avatar
code3GT
Mustang Nazi
Rubbing or alcohol or "goof off" will not hurt the paint.
