exhaust sound changing
Old Sep 8, 2003 | 04:44 AM
silvergt46's Avatar
silvergt46
Default exhaust sound changing
I got a problem. I purchased my bassani x pipe about 2 years ago and i just installed my bassani cat back system about 6 months ago. I say about 3 months ago the tone changed from BASS to just being loud. What could cause the tone to change so much. According to the mechanic the exhaust is suppose to get louder once it settles however mine did the exact opposite. I don't understand. I took it back to the shop and he checked for exhaust leaks but he said that there is no carbon deposits on the pipes (black marks or some crap) and he said there was none. But the tone changes every day when i crank it up. I also noticed that i can hear water hitting the x pipe and sizzling. A matter of fact water is running down the right pipe right before the cat. Some one please help cause i payed BIG MONEY for my exhaust so i can sound different and now it sucks. Thanks!</P>
Old Sep 8, 2003 | 10:24 AM
BCisme's Avatar
BCisme
if your tone is changing, and getting unbearably loud,your exhaust must have a hole in it somewhere. i just can't think of anything else.
Old Sep 8, 2003 | 10:29 AM
silvergt46's Avatar
silvergt46
the tone is not unbearable but the tone has changed from being pure bass to non bass i don't understand why it has happened but i do think i have a leak plus i sam smelling gas wheni first crank up my car in the morning
Old Sep 8, 2003 | 01:29 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Tighten up all your exhaust bolts, like headers etc. Also check your clamps or welds
Old Sep 8, 2003 | 01:35 PM
awwimer's Avatar
awwimer
the water is from the air conditioning and the tone change is most likely resinating of the mufflers. but if there was a hole check where the pipes go over the rear end some after market tend to rub there and would eventually rub through.
Old Sep 8, 2003 | 09:16 PM
gdear66's Avatar
gdear66
If water is coming around the cats then check for leaks high up including the gaskets around the headers. That may be your source. I agree with BCisme I think you've got a hole somewhere.
Old Sep 9, 2003 | 08:27 AM
silvergt46's Avatar
silvergt46
Thanks guys but one I have never ever received any head work on my the stock block has been untouched however, the shop that i did go to has a rep for sucking butt in the installation department! They put a upgraded radiator on my friends 82 with a 351.....and they did not replace the fluid in it!
Old Sep 10, 2003 | 03:56 AM
2002 Stang GT's Avatar
2002 Stang GT
The sam thing happened to me, at first my car got wayyyy to loud with the stock exhause, they said that one of the mufflers became loose, then they fixed it and it became wayyyyyyy to quiet, now whenever i drive a lot and close my door the right cat always sizzles when i close my door, and at idle the right exit pipe always rattles and makes a lot of noise noticable even when in the car windows up, i took it to ford and they said they could not find anything worng with it, its just like ur situation except mine became quiet, and yes water came out of the cat and only that one not the other one, and it made a lot if sizlling sounds, i thoought the cat was blown or something but ford told me it was fine, i dont know whats wrong with it<IMG src=smileys/smiley19.gif border="0"><edited><editID>2002 Stang GT</editID><editDate>37874.0816898148</editDate></edited>
Old Sep 10, 2003 | 08:18 AM
silvergt46's Avatar
silvergt46
Beats the hell out of me, i don't know what is going on with my baby<IMG src=smileys/smiley19.gif border="0"> But, hell it still sounds good but it does not have the bassani sound a matter of fact i shall try to post the sound on the web forum if it is possible. If any has ever heard a mustang with bassani cat backs, you know that is a different sound from any other cat back in existence.<IMG src=smileys/smiley16.gif border="0">!!!!!!!!!!!!!!!
Old Sep 10, 2003 | 08:54 PM
2002 Stang GT
that would be coo if u posted it cause i want to buy the bassani cat back
