anyone i need help!
alright i have white apint splattered onmy car i tried jus scrubbing it off i tried scratching off and then i tried clay baring it is there anything else i can do tht will not ruin my actual car paint?
this is my front right wheel well part of the side skirt
[IMG]local://upfiles/75167/ED7DDCED8D7D47E7944B8AFFFB3B7B0F.jpg[/IMG]
this is my back bumper the side of it
[IMG]local://upfiles/75167/2BAC574B6ABF486A823C7AF45C838691.jpg[/IMG]
Patience and a clay bar will take it off. If you can't get overspray off with a clay bar you're using it wrong. Other than that a buffer with some compound will remove it, but the clay bar is the best option.
I have a can of something that may get it right off. I'll let you know what it is when I get home. If forgot what it's call, but i"ve used it to remove 3 day old paint off my whitebaseboards on my house. My mother used it to clean black paint off a couch and yellow paint off a red truck. Just make sure you use it on an inconspicious spot first
It's called Goof Off and it's in a yellow can with a red top
http://www.valsparglobal.com/val/resident/goof-off.jsp
did the goof off work? i've used it to remove adhesive from paint after i took emblems off. if all else fails wetsanding would work, but i would take it to someone who knows what they're doing....wetsanding can make your paint head south in a hurry
