Tire Shine
Old Aug 11, 2007 | 01:19 PM
britt21's Avatar
britt21
Default Tire Shine
What do you all use to clean your tires with??
Everything I use, looks like crap within like two days.
Old Aug 11, 2007 | 02:22 PM
SVTBill's Avatar
SVTBill
Default RE: Tire Shine
my boss at work (discount tire) gave me a huge gallon of the meguiar's tire shine that has to be diluted in order to use (diluted with water)..i use that and it works awesome, but its only available to major companies, its not really over the shelf....but when i was buying stuff on the shelf i used meguiar's hot shine (the spray kind in a bottle), not the arisol can - if you do want an arisol can spray - because it's easy the nxt spay works awesome, while all other arisol's suck ballz and run off
Old Aug 11, 2007 | 02:38 PM
DJPcustoms's Avatar
DJPcustoms
+1 to Hot Shine, actually lasts awhile and doesnt attract as much crap as the Armor All Gel I was using.
Old Aug 11, 2007 | 03:03 PM
Juztang's Avatar
Juztang
Make sure you get your tires really clean before you apply any tire dressing. I use an all purpose cleaner and a brush to clean tires, this gets them completely clean for the dressing. I mainly use Poorboys Bold N Bright. It dries to the touch and isn't greasy at all. Another good thing about it is that it is water based, a lot of tire dressings are oil based and can cause the tires to turn brown and actually dry them out. Bold N Bright can also be diluted 1:1 for fenderwells and engine bays.
Old Aug 11, 2007 | 07:12 PM
britt21's Avatar
britt21
alright thanks!
Old Aug 12, 2007 | 10:18 AM
2004YellowStang's Avatar
2004YellowStang
Eagle one makes a really good tire cleaner that is reasonablly priced. Use that first then then wash and use the tire shine of your choice after it's dry. I use armor all extreme tire gel. It's basically as good as the more expensive tire shines but at a very reasonable price. And if properly applied attracts very little dirt and won't sling off.
Old Aug 13, 2007 | 05:45 PM
seanpaintsflames's Avatar
seanpaintsflames
Also, you can put tire dressing on with a paint brush instead of that foam pad they tell you to. Just pour it in a metal paint can. Some dressings will eat through a plastic cup. But that way, you're not paying for dressing that's just soaking into a sponge in your garage.
Old Aug 14, 2007 | 04:25 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Wesleys bleach white for cleaning the tires and Zaino perfect tire gloss for shine and FTW!
Old Aug 14, 2007 | 11:36 AM
steedondubs's Avatar
steedondubs
Armor All Extreme tire Gel... Its cool... Comes with an applicator sponge that comes in handy...
Old Aug 14, 2007 | 02:12 PM
GTwannabe's Avatar
GTwannabe
i use the regular armor all in the white spray bottle.. when you spray it on it is gonna look white and all.. but let it sit for about 30 minutes and let it soak in and it will shine REALLY good and last for a while.. even after it wears off your tires will still have the black look instead of looking dull
