Non-shine paint?
Old Aug 25, 2007 | 10:58 PM
scarslilpyro's Avatar
scarslilpyro
Default Non-shine paint?
Other then primer, is there an alternative to shiny paint?
Can you use primer as the paint?
Old Aug 25, 2007 | 11:15 PM
3.8_Special's Avatar
3.8_Special
Default RE: Non-shine paint?
No you can't. Primer is peimer and paint is paint. Primer is only designed to act as a primer and hold the paint on after it. If you prime and just leave it you will get corrosion (rust/ iron oxide) and need to go through the whole processof sanding, preping and paintingagain.
You can easley buy flat and semi gloss apint as well as gloss paint.
Old Aug 25, 2007 | 11:18 PM
scarslilpyro
ORIGINAL: 3.8_Special
Alright thanks, any tips on doing it myself? Any spray cans that are worthy of useing as paint? I'm kind of tight on money right now.
Old Aug 26, 2007 | 08:30 AM
3.8_Special
... What are you painting and what kind of quality do you want?
Old Aug 26, 2007 | 07:22 PM
scarslilpyro
First thing would be the trunk since it was covered in rust. I just want it to be one color, and grey, because the interior is grey. I want to be able to wash/wipe it down. I really don't know because I'm new to paint.
Old Aug 26, 2007 | 08:33 PM
3.8_Special
Are you looking for a good quality job or just somthing grey that kind of matches your car?
If your doing it by your self and have no experience Idont think you would have any of the tools or supplies for a good job. The basic supplies are easy and cheep using spray cans/ spray bombs.
Do you want a step by step?
Old Aug 26, 2007 | 09:27 PM
scarslilpyro
Yeah a step by step would be great. I'll have to practice on the trunk or hood which is a good place to start.
Old Aug 26, 2007 | 10:06 PM
jakeachy's Avatar
jakeachy
it will last for a month or two though. DEFINATLY not worth the risk
Old Aug 27, 2007 | 01:28 PM
3.8_Special
can you tell me what kind of shape it is in now?
Old Aug 27, 2007 | 09:38 PM
ktm300's Avatar
ktm300
There are different kinds of primer, the 2 main ones are Self Etching (accidic) primer which is used on bare metal. Then there is Primer Surfacer which goes ontop of the etching primer, and is used to fill slight imperfections and is sandable.
As for the semigloss paint, pick whatever color you like and when you go to clear coat it. You can add some flattenting agent to give that matte look. It dulls the clear out and keeps it from being as shiny as it could be. I'd really hate to see you go the spray paint route, it would be best to buy the materials and have a shop spray it for you. You will save a ton of money by prepping it yourself, if all they have to do is mask and paint it.
