Waxing
Old Sep 14, 2007 | 09:13 AM
blane17's Avatar
blane17
Default Waxing
Not sure if I have 1 step or 2 step paint (base coat/clear coat) on my car. Does this affect how I would care for my paint?
Old Sep 15, 2007 | 04:31 AM
ktm300's Avatar
ktm300
Default RE: Waxing
Yes, some single stage products will damage bc/cc paint. Just use products that say clearcoat safe.
If you can find a hidden spot, such as under weather stripping, then you could sand a little bit of the paint with some 400 grit or so. If it makes white powder then you have a clear coat, and if its red/orange? then its prob single stage.
Old Sep 15, 2007 | 11:46 AM
Jim D.'s Avatar
Jim D.
Default RE: Waxing
If you use a simple carnauba cleaner wax, pre-wax cleaner, or even a light polish or scratch remover, it should bring up some car color on the applicator during normal application.
If you're just waxing by hand or random-orbital, and using regular consumer products (even a 3-step system), it really makes no difference. Most everything is clearcoat-safe these days (either read the front or back side of the label).
If you do have a clearcoat -- or are not sure -- avoid extended use of a rubbing compound (usually only used for heavy oxidation) and other strong products and you'll be fine.
Mr. D
Sep 17, 2015 08:17 AM
Aznxwidxmustang
Jun 24, 2005 01:32 PM
ParrotHead
Sep 1, 2004 09:35 PM
atlantic pony
Sep 17, 2003 12:17 PM
